Example symbol Gallery
jhaskins20018
Post by jhaskins20018 » Mon Nov 30, 2020 3:35 am
Is there a download link for extra symbols to be added to the library
Re: Example symbol Gallery
Post by CVH » Mon Nov 30, 2020 5:10 am
I think you might find anything related to your question here:
https://qcad.org/en/tutorial-working-wi ... rt-library
There are much more other things explained on the QCAD site. :wink:
It tickles down to:
Symbols, parts, ... and so on, are merely (small) drawing files.
About every dxf/dwg can be used as a 'part'.
Configurable library scripts are also a possibility.
One thing to remember is that once these are inserted in a drawing there is NO link with the library item itself.
Browse the Forum on 'Library' for that.
Return to “Chat”
