script not working
dfriasb
Senior Member
script not working
Post by dfriasb » Sat May 02, 2020 3:51 pm
Dear all,
I have reviewed this code many times but I can't find what is not working. When I paste the central part in QCAD script console it works great, but not when try it as a command. I guess it is something related with guiAction; looks like action is not completed...
Any help will be very welcomed.
Best regards,
David
This is the code that works correctly on console:
	var doc = this.getDocument();
	var selectedEntities = doc.querySelectedEntities();
	var op = new RAddObjectsOperation();
for (i=0; i<selectedEntities.length; i++)	{
entity = doc.queryEntity(selectedEntities[i]);
if (!isBlockReferenceEntity(entity)) {continue;}
blockName = entity.getReferencedBlockName();
blockRefPosition = entity.getPosition();
blockRefAngle = entity.getRotation()*360/(2*Math.PI);
// impressió ::
printText = addSimpleText(blockName, blockRefPosition, 0.003, blockRefAngle, "Cotes", RS.VAlignMiddle, RS.HAlignCenter, false, false);
op.addObject(printText);}
And this is the complete file:
// prints all selected block references block names. Text angle displayed is block reference rotation angle ::
//  !!!  something is not working when starting the command on QCAD.
include("../DFa.js");
include("simple.js");
function printblocknameselected(guiAction) {
	DFa.call(this, guiAction);}
printblocknameselected.prototype = new DFa();
printblocknameselected.prototype.beginEvent = function() {
	DFa.prototype.beginEvent.call(this);
// THIS PART IS WORKING IN QCAD SCRIPT CONSOLE :
// impressió ::
// TIL HERE.
di.applyOperation(op);
this.terminate();
// Adds menu&command for this action::
printblocknameselected.init = function(basePath) {
    var action = new RGuiAction(qsTr("&printblocknameselected"), RMainWindowQt.getMainWindow());
    action.setScriptFile(basePath + "/printblocknameselected.js");
    action.setDefaultCommands(["bnames"]);
    action.setDefaultShortcut(new QKeySequence("b,n"));
    action.setGroupSortOrder(78100);
    action.setSortOrder(200);
    action.setWidgetNames(["DFaMenu"]);
(1.64 KiB) Downloaded 50 times
Re: script not working
Post by andrew » Tue May 05, 2020 9:40 am
This seems to work fine here (adds a small text at selected block reference coordinates). I did have to make a few tweaks (fix include paths, no operation needed in Simple API). Note that I'm deriving from EAction as I don't have DFa.js and I'm adding to the menu Misc > Block. I also increased the text size (easier for testing).
include("scripts/EAction.js");
include("scripts/simple.js");
    EAction.call(this, guiAction);
printblocknameselected.prototype = new EAction();
    EAction.prototype.beginEvent.call(this);
            continue;
        // impressió ::
        addSimpleText(blockName, blockRefPosition, 1, blockRefAngle, "Cotes", RS.VAlignMiddle, RS.HAlignCenter, false, false);
    // TIL HERE.
    this.terminate();
    action.setWidgetNames(["MiscBlockMenu"]);
dfriasb
Senior Member
Post by dfriasb » Tue May 05, 2020 3:00 pm
Thank you Andrew,
Now it's working also for me. I moved to /Misc and changed DFa.js by EAction.js. So I think the bug is in my DFa.js file.
Regards, David.
