Viewports with different layers visible
Joern73
Post by Joern73 » Wed Mar 18, 2020 4:09 pm
Hallo everybody,
is it possible to have two or more different vieports on one layout with different layers visible.
So that I could see viewport one with layerstate one and viewport two with layerstate two.
Thank you and stay healthy!!
Re: Viewports with different layers visible
Post by Husky » Wed Mar 18, 2020 7:19 pm
Hallo,
... is it possible to have two or more different vieports on one layout with different layers visible.
No ...
... but you can easily duplicate layer (shortcut yy) and use them then for the second viewport. Yes, it's a kind of workaround but on that way you can use one layerstate for both viewports.
... stay healthy!!
You too!
Return to “Chat”
