Different Font Size Between AUTOCAD and QCAD
jssham
Post by jssham » Sun Jan 05, 2020 3:13 am
I open my DWG drawing in AUTOCAD, the font was ok.
But when I tried to use QCAD, the font was something wrong.
P/S: I'm using QCAD in ubuntu 19.04.
Font Size Mising
Screenshot from 2020-01-05 10-03-25.png (7.25 KiB) Viewed 676 times
Re: Different Font Size Between AUTOCAD and QCAD
Post by Husky » Sun Jan 05, 2020 5:11 am
Please be more precisely with the issue description. If possible attach the dwg in question.
Basic question: Have both programs access to the same set of fonts?
jssham
Post by jssham » Sun Jan 05, 2020 4:17 pm
Yes, both programs were access to the same set of fonts
jssham
Post by jssham » Mon Jan 06, 2020 3:00 am
I had attached the sample DWG.
TEST.dwg
(27.16 KiB) Downloaded 34 times
Panchdara
Senior Member
Post by Panchdara » Mon Jan 06, 2020 11:25 am
jssham - question:
exactly what?? do you expect to see? Can you show what the "correct" text/font looks like and what the "incorrect" text/font looks like?
Cheers
QCAD 3.24.3 / Windows 10 x86_64
jssham
Post by jssham » Mon Jan 06, 2020 11:35 am
This is what I expected.
From AUTOCAD
From QCAD
Screenshot from 2020-01-06 18-33-30.png (19.84 KiB) Viewed 595 times
Panchdara
Senior Member
Post by Panchdara » Mon Jan 06, 2020 11:48 am
Thanks jssham. Makes a lot more sense. Can you save the original (Autocad version) in DXF format? Looks sorta like an import issue? I'm sure Andrew will figure out - I was just trying to see where the differences were. I guess ACad might save DWG files using their proprietary format(s) and even then their formats might differ from version to version.
Best
(Edit: or try again without any alignment settings on the text??? ) Best
Post by andrew » Mon Jan 06, 2020 2:04 pm
Autocad uses various text formatting codes, some of which are not supported in QCAD.
"\pxsm1.5,qc;" is such a code. I haven't seen this before with the ",qc" part. I've added this to be ignored in future versions to avoid displaying the code itself. There are currently no plans to add support for individual text line spacing through these codes.
