Blue circle on printouts - why?
TimothyC
Post by TimothyC » Tue Dec 17, 2019 6:16 pm
Greetings from Michigan
I just tried the "64 bit trial version" and within minutes purchased the "64 bit version of QCAD." When I try to print a blue filled circle appears on my drawing. Is that a left over from the trial version. If so, how do I get rid of it?
I'm just an "old guy" who likes to code and make drawings to support my various hobbies.
Thanks in advance for help!
Tim
Re: Blue circle on printouts - why?
Post by andrew » Tue Dec 17, 2019 6:23 pm
No, likely a misconfiguration of sorts.
Please post your drawing file (DXF/DWG) and a screenshot, so we can see what you mean.
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- Attach exported files (SVG, PNG, PDF, ...) if appropriate
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
- If using a command line tool, indicate that exact command used
TimothyC
Post by TimothyC » Tue Dec 17, 2019 6:32 pm
Andrew,
Thank you for your quick reply.
Here's a picture of the screen after selecting "PRINT PREVIEW"
And here's the DXF file I am trying to print: (as attachment)
Version: 3.23.0.0 (3.23.0)
Internet: QCAD.org
Build Date: Jul 18 2019
Revision: 42e52bf
Qt Version: 5.5.1
Architecture: x86_64
Compiler: MSVC++ 12.0 (2013)
The graphic "SPRITE" is the logo found on Austin Healey Sprite automobiles about as close as I can model it.
Tim
SPROOF.DXF
(29.45 KiB) Downloaded 43 times
Post by Husky » Tue Dec 17, 2019 7:26 pm
For some unknown reason there is one blue Point (Entity) in your drawing. Delete it and your issue is solved. To catch that point I recommend to use the selection filter - makes your life easier. :wink:
TimothyC
Post by TimothyC » Tue Dec 17, 2019 8:31 pm
Deleting the blue circle would be the easy fix, wouldn't it? However, the blue circle doesn't appear until after I select "PRINT PREVIEW." When I select the "RED X" to cancel the printing process, it goes away.
I have successfully printed another file now, so I suspect there is something about that particular dxf file that is funny. I plan to look at the file in a text editor to see if I can find a filled circle element hiding somewhere.
Thanks for the suggestion.
Tim
Post by andrew » Tue Dec 17, 2019 8:42 pm
You can simply click the blue point in the print preview to select it and hit delete.
Or, as Husky suggested, use the selection filter (View > Selection Filter).
Or reduce the point printing size under:
Edit > Drawing Preferences > Printing > Page > Point Size (mm)
TimothyC
Re: Blue circle on printouts - why? SOLVED
Post by TimothyC » Tue Dec 17, 2019 9:11 pm
Andrew,
Your second suggestion made the difference. Specifically, "drawing units" had not been selected/specified. When I specified "inches" all was well with PRINT PREVIEW.
Thank you
Tim
