How to get currently editing block name in Script Shell
dfriasb
Senior Member
Post by dfriasb » Sat Dec 07, 2019 3:59 pm
Dear all,
I can't find the way to get the Id of the block that I am editing right now. I have all the block Ids with these line:
var blockIds = document.queryAllBlocks();
Then I should find "currently editing" block somehow...
And then apply:
var block = document.queryBlock(blockId);
var blockName = block.getName();
where block is the blockId that I'm looking for.
I'm also asking myself if document variable definition line should be diferent. I'm writing this one:
var document = this.getDocument();
or
var document = this.getDocumentInterface();
Does exist any getBlockDocument like? I mean get document entities only inside some block...
Any help will be very welcomed!
Re: How to get currently editing block name in Script Shell
Post by andrew » Tue Dec 10, 2019 2:25 pm
var blockId = doc.getCurrentBlockId();
doc.queryBlockEntities(blockId);
