[solved] Cutting square corners on island
n_spect_r
Post by n_spect_r » Tue Dec 03, 2019 3:25 pm
I have searched for this and so far no luck. I'm cutting an island, it's square in the middle of a heat sink. The print has square corners, my drawing has square corners but the path puts a radius matching the tool radius. Which is great for the roughing cuts, I still need to square the corners though.
Re: Cutting square corners on island
Post by Husky » Tue Dec 03, 2019 6:28 pm
I assume that is a question to QCAD/CAM. Correct?
Please attache the drawing or an example drawing which shows the issue. Thanks.
n_spect_r
Post by n_spect_r » Tue Dec 03, 2019 7:15 pm
Actually it worked right. It looked funny in the drawing, but as the radius is equal to the tool radius the corners are essentially square.
Post by CVH » Tue Dec 03, 2019 7:48 pm
A circular tool cutting follows a circular path arround a hard corner!!
QCADpro 3.24.3.10 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Post by Husky » Tue Dec 03, 2019 8:37 pm
Great - I moved the topic to QCAD/CAM and marked it as solved.
