Get the error when trying to open the following files - "Can not open file Please check your access rights, file format,
MTBiker
Post by MTBiker » Fri Nov 15, 2019 8:29 pm
I get the error when i try to open this file that was sent to me that was created in AutoCAD. I had them send it to me as a .dwg and .dxf and neither would work.
2019-11-15 13_28_41-QCAD.png (11.54 KiB) Viewed 826 times
10-EL-0090_1.dxf
(3.92 MiB) Downloaded 67 times
10-EL-0090_1.dwg
(396.94 KiB) Downloaded 60 times
Re: Get the error when trying to open the following files - "Can not open file Please check your access rights, file for
Post by andrew » Fri Nov 15, 2019 8:36 pm
Please indicate your operating system and QCAD version, thanks.
MTBiker
Post by MTBiker » Fri Nov 15, 2019 9:59 pm
Windows 10 Pro
3.7.0.0 (3.7.0)
Post by Husky » Fri Nov 15, 2019 10:01 pm
I'm able to open the drawing without any problems.
Looks like a Win operation system ...
Is that a onedrive sync folder? I assume it is an access right issue ...
Try to save the drawing on the desktop and open it from there. Same message?
Post by andrew » Fri Nov 15, 2019 10:06 pm
Thanks.
There are different versions of the DXF format. This file is a DXF of version R32 (first released in March 2017). Your QCAD version 3.7.0 is from 2014 and does not support that DXF version.
The current version of QCAD (3.23.0) can read and write files in DXF R32.
