Is this where I report problems?
chuckt
Post by chuckt » Fri Sep 06, 2019 12:32 am
In the profile dialog, if I set the start depth and the cut depth to the same value, the system goes into an endless loop. To stop it, you have to quit QCAD.
I am running on Ubuntu 18.04LTS and I have QCAD/CAM V3.23
I know this is a stupid thing, but it I wish it would just bail, rather than endlessly loop.
Re: Is this where I report problems?
Post by Husky » Fri Sep 06, 2019 6:30 am
For a bug report or a feature request please use https://www.qcad.org/bugtracker
A bug report posted in this forum could be "forgotten" what never happens in that mentioned dedicated forum. :wink:
Unfortunately that forum needs a separate registration, your login from this forum will not work.
chuckt
Post by chuckt » Fri Sep 06, 2019 6:46 pm
I looked at the bug tracker, but I did not see a way to register or login. Do I need to apply or something?
All the best!
Chuck Tilbury
http:/whistlemaker.com
Post by Husky » Fri Sep 06, 2019 7:32 pm
Yes.There should be a link (Login) at the upper right corner or just use this ling for the first registration:
https://www.qcad.org/bugtracker/index.php?do=register
