- Bildschirmfoto 2019-07-07 um 12.25.11.png (14.35 KiB) Viewed 5383 times
Snapping on center of a rectangular shape (4 lines)
I want to put a drill hole (small circle) in the midpoint of a rectangle (formed of 4 separate surrounding lines). How can I adjust the snap mode such that the cursor snaps to the midpoint of the (green marked) area?
Christoph
Christoph
Re: Snapping on center of a rectangular shape (4 lines)
In this particular situation you can use the "Center of Selection" snap. In other situation the "Middle Manual" snap will provide the solution.
Thanks. Found it in the drop down menu (SK). Does not appear in the left icon bar.
Christoph
Christoph
