Trimming ARCs and LINEs
Krischu
Senior Member
Post by Krischu » Thu Jul 04, 2019 5:08 pm
I'm trying to draw a developed view of a small sheet metal case.
How can I trim the little half- and quarter-arcs in the folding corners?
Christoph
Bildschirmfoto 2019-07-04 um 18.02.08.png (365.57 KiB) Viewed 3472 times
Christoph
Re: Trimming ARCs and LINEs
Post by Husky » Thu Jul 04, 2019 6:35 pm
Please have a look at this "Modify" tools:
Krischu
Senior Member
Post by Krischu » Fri Jul 05, 2019 8:58 am
Thanks. I looked at it but I have no idea as to
  • what menu topic I should choose between D2, B2 and AX
  • which elements to click at which points
  • whether to select an element first or not
The attached screenshots are showing what I would like to achieve. Not that you think that I already managed to do so :). I used Gimp to edit the screenshot to obtain the result.
Bildschirmfoto 2019-07-05 um 09.43.36.png (33.77 KiB) Viewed 3446 times
Christoph
Post by andrew » Fri Jul 05, 2019 9:17 am
Please refer to the user manual for step by step instructions for each of these tools, under Help > Reference Manual or online at:
https://qcad.org/doc/qcad/latest/reference/en/
Krischu
Senior Member
Post by Krischu » Fri Jul 05, 2019 10:48 am
I think the problem why I couldn't get ahead was that the line shape is a polygon. Can I resolve a PL into lines?
Christoph
Post by andrew » Fri Jul 05, 2019 10:51 am
Are you using QCAD Professional or the free QCAD Community Edition?
Krischu
Senior Member
Post by Krischu » Fri Jul 05, 2019 11:09 am
The free Community Edition
Christoph
Post by andrew » Fri Jul 05, 2019 11:11 am
OK, thanks. I'll move your posts to the appropriate forum for the QCAD Community Edition.
Krischu
Senior Member
Post by Krischu » Fri Jul 05, 2019 12:55 pm
Thanks. Wasn't aware that I had been posting in the Qcad Pro section of the forum.
Back to the matter:
All the hassle I had and why I could not solve my problem intuitively with the suggested D2/B2 commands was, that my object was a PL (polyline) !
Thus my questsion in another thread how to resolve a PL into LI segments.
Christoph
