Strange things happening with blocks in file
garciadelcastillo
Post by garciadelcastillo » Thu Jun 06, 2019 7:31 pm
Hi there,
Problem: I am running into a strange problem with some block references in a reduced number of cad files being rendered in strange places.
Description: I have a routine that batch-rasterizes cad files. The script relies on "dwg2bmp" with the "-zoom-all" argument. However, I started noticing that for some files, the zoom all option zoom out too much to objects that didn't seem to be on the drawing.
For example, for the following file:
family_house_2_first.dwg
(220.19 KiB) Downloaded 172 times
I get a rasterized image like this:
If I open the file in a different software and "zoom all", I get everything in the right place:
However, when I open the same file with the QCAD GUI (no zoom all), I get this:
Notice that in the QCAD version, the chair and computer on the desk of the lower right corner of room 210 are missing. On zoom all, I get the same view bounding box as in the rasterization process:
Now, if I zoom on the brown dot at the bottom, the missing chair is there:
But if I try to select it and zoom out, the selection box is offset by +3000 units!
The missing laptop (part of the same block) is to be found on the top part of the drawing, but this one doesn't allow to be selected:
So, I guess my question is if you think this is a problem with the files or with the way QCAD renders these strange blocks. This problem doesn't seem to appear when opening the files with other software.
Here is a collection of other files that have similar issues:
badZoom.zip
(6.93 MiB) Downloaded 216 times
Thank you so much in advance! :)
Re: Strange things happening with blocks in file
Post by andrew » Thu Jun 06, 2019 8:47 pm
These blocks use block transforms (a transformation matrix for block references). This is currently not supported by QCAD as it seems to be a rather uncommon feature of the DXF/DWG formats.
I've added a feature request at:
https://qcad.org/bugtracker/index.php?d ... sk_id=1895
garciadelcastillo
Post by garciadelcastillo » Thu Jun 06, 2019 9:08 pm
Thank you andrew!
garciadelcastillo
Post by garciadelcastillo » Mon Jun 10, 2019 6:04 pm
Hi Andrew,
Is there any way to detect which blocks use block transforms from the ECMAScript API? While the FR goes through, I would like at least to be able to remove those blocks from the drawing prior to rasterizing them.
Thanks!
Post by andrew » Tue Jun 11, 2019 9:12 am
Unfortunately not. QCAD does not import such transformation matrices at all.
