Subscript issue
miha
Subscript issue
Post by miha » Fri May 10, 2019 8:37 pm
I tried to write "R2", where R is italic and 2 is subscript. However, the output is source text (I attached the figure). Can someone help me with this issue?
P.S. I use QCAD 3.22 - Pro version.
Screenshot 2019-05-10 at 21.17.12.png (23.93 KiB) Viewed 1622 times
Re: Subscript issue
Post by Husky » Fri May 10, 2019 9:33 pm
Please deactivate "Simple Text" and check what happens.
Re: Subscript issue
Post by andrew » Fri May 10, 2019 10:00 pm
This specific formatting (text change, color change or font size change right before subscript / superscript) gets messed up by the text dialog. Bug report added under:
https://qcad.org/bugtracker/index.php?d ... sk_id=1885
As a workaround, you can enter this code for the text in the property editor:
\fTimes New Roman|b0|i1|c0|p0;R\fTimes New Roman|b0|i0|c0|p0;\S^2;
Unfortunately, using the text dialog to edit this text, will mess it up again...
miha
Re: Subscript issue
Post by miha » Fri May 10, 2019 10:35 pm
Thank you for quick and useful answer! :D
I tried what you suggested and it works. I hope future versions of QCAD will allow for easier text manipulation.
Best regards,
Mihael
