[solved]Dimension text garbled, and text can't edited
t.ogawa
Post by t.ogawa » Thu May 09, 2019 8:59 am
Software:QCAD Pro 3.22.0.0
OS:Mac Mojave
Hello.
I have some questions about the dimension text.
1.
When i open a dxf file in QCAD and select japanese fonts, only the dimension text remains garbled.
But the multitext part is not garbled.
And it is garbled even when I export PDF from QCAD screen.
However, there is no garbled character when exporting PDF from command line tool.
use command:
dwg2pdf -l -a -k -fs standard Arial -paper=A3
2.
I can not edit the text by double-clicking this Dimension text.
3.
Dimension text has been rotated.
Is this a QCAD specification?
(Im expecting an "autocad_ss.png")
Thank you.
Re: Dimension text garbled, and text can't edited
Post by andrew » Thu May 09, 2019 9:38 am
You can change the dimension font under:
Edit > Drawing Preferences > Dimension > Dimension Settings > Dimension Label Font
That's correct. You can edit dimension labels using the property editor.
QCAD does not support the dimension style used by Autocad.
t.ogawa
Post by t.ogawa » Thu May 09, 2019 10:13 am
Hi andrew.
Thank you for reply.
It is solved. Thank you very much! :D
I see, I understand.It is a little disappointing...
Thank you.
