Block array: Row and column spacing changes when converting drawing units
smo
Post by smo » Sun Apr 14, 2019 5:41 pm
I inserted a block array into a drawing. When I then convert the drawing units, the row and column spacing is not changed correctly.
Steps to reproduce:
  • Insert a block with i.e. 3 columns, 2 rows, column spacing 400, row spacing 600 (see before.jpg)
  • Edit=>convert drawing unit - from mm to cm
  • The distances change by a factor of 10 (see after.jpg).
QCAD Professional Version: 3.22.0.0 (3.22.0)
Architecture: x86_64 Windows-10
test.dxf
(103.32 KiB) Downloaded 324 times
