Need help with a custom postprocessor for Mach3 Plasma table
Lazer
Post by Lazer » Sat Mar 09, 2019 10:46 pm
I need help creating a new custom postprocessor for Mach3 plasma table. I tried the G-code that "Mach3(G41/G42)in" generates and run it on the machine. It mostly works on the machine, but it does not shut off plasma at the end of each contour. I edited the G-code file manually and changed the Z2 (goto z 2 inches safety height) to M5, and it works correctly now. I just need to know how and where to change (or add the M5) the Z2 line to M5 line instead in the postprocessors, and in which postprocessor in particular.
Re: Need help with a custom postprocessor for Mach3 Plasma table
Post by andrew » Sun Mar 10, 2019 1:08 am
The "Mach3 Laser (G41/G42) in" postprocessor is likely closer to what you need.
You can adjust "this.zPassHeader" and "this.zPassFooter" accordingly, for example:
    this.zPassHeader = [
        "[N] (replace this with the code to switch the laser on)"
    this.zPassFooter = [
        "[N] (replace this with the code to switch the laser off)"
Lazer
Post by Lazer » Tue Mar 12, 2019 11:30 pm
Thanks for the help Andrew! I really appreciate it!
I did create a custom postprocessor and I included the lines you suggested, plus I added some other tweaks to it and now its perfect. Works like a charm.
Post by andrew » Wed Mar 13, 2019 9:12 am
You're welcome. Good to hear it's working now.
