[solved] dwg2maptiles
simtaylo
Post by simtaylo » Tue Dec 18, 2018 1:29 pm
I have not been able to get dwg2maptiles to work on my MAC. I go to the Applications/QCAD-Pro.app/Contents/Resources folder and execute a command like :
./dwg2maptiles -t png /Users/simtaylo/Downloads/test/SJCI_1_Prime.dwg
Hoping this will pull the .dwg file and create the tiles in the same test folder.
I get no error and nothing created.
I expect this is something very simple I am doing wrong ?
Re: dwg2maptiles
Post by andrew » Tue Dec 18, 2018 1:35 pm
Can you check if the file /Applications/QCAD-Pro.app/Contents/Resources/qcad is empty? If so, please follow the instructions at:
viewtopic.php?f=32&t=5925&p=22082&hilit ... les#p22082
-> See the fourth post, the one with the file "qcad.zip" attached.
simtaylo
Re: dwg2maptiles
Post by simtaylo » Tue Dec 18, 2018 1:41 pm
That did the trick ... thank you
