always when I have to work on something like this I would love to use the "Paste along Entity" tool for holes etc. ...
... but the tool doesn't accepts circle etc. . There is no warning when I pick an entity which isn't accepted - it's just not working.
I think it can't work on circle etc because there is no information "where to start". Generally this is already a powerful tool and arranging something on a circle is a daily task.
Is there a way to enhance this tool so it works on all entity's? Maybe asking for an additional click for the Start point ... ?
Edit:
To get all out of my mind regarding this "Paste along Entity" tool.
The missing option where to start with inserting along an entity leads most of the time (in my cases) that I have to put extra effort into the task to finish an inserting manually.
Would be nice to have an option like the "Restrict Angle or Lengths" tool to choose the base value by ourself. Maybe an Option Box "Base 0" yes/no.
"Paste along Entity" for Circle etc.
Re: "Paste along Entity" for Circle etc.
Yes.I think it can't work on circle etc because there is no information "where to start".
The tool could assume that you want to start at angle 0 for circles which would probably cover most use cases. What I'm trying to avoid is that every tool becomes an eierlegende Wollmilchsau
I'd recommend the Rotate tool (or the Rotate Two tool) for such use cases. These are the specialized tools for arranging things in circular patterns.Generally this is already a powerful tool and arranging something on a circle is a daily task.
An option to include start- / endpoints sounds like a good idea.
I checked the Snapshot regarding this feature request and I've to say: I can't ask for more! Well done! Thank you very much!
Yes, thank you very much, but ...
I can ask for more.
When creating a bank it would help to place objects with an Offset (see attached example).
I can ask for more.
