Cursor - shifted
4kx
Cursor - shifted
Post by 4kx » Fri Aug 31, 2018 6:36 pm
The problem on the pic below:
cursor is shifted related to real position of the cursor - all the time.
This happened just a moment ago, when i was using polyline tool. And stayed like this on any tool.
How to fix that?
Reinstalation of the program when this will happen again?
Re: Cursor - shifted
Post by Husky » Fri Aug 31, 2018 6:53 pm
please indicate Operating system, QCAD version, attach Drawing files, Screenshots. Thanks.
Clive
Moderator / Drawing Help
Post by Clive » Fri Aug 31, 2018 9:40 pm
Could this be snapping to the grid, try looking at your snapping set up.
