crash QCAD/CAM v3.20
cki61
Post by cki61 » Mon Apr 30, 2018 4:26 pm
Hi Andrew,
thank you very much for the new version. The option to set taps is very helpfull. Great work!
I think you are intrested in a bug since that version (I'm not shure, maybe the version before).
1. load a file
2. close the file
3. load the same file again
4. click CAM Configuration -> 100% CPU -> kill -9
A click on CAM Configuration when opened first time works.
I use the Linux Version with leap 42.3 all updates.
The file used is attached.
If you nee more information, no problem.
Best Regards,
Christof
Fassung_MPX_4Buchsen.dxf
(236.54 KiB) Downloaded 225 times
