Project with QCAD / CAM
Clive
Moderator / Drawing Help
Post by Clive » Thu Aug 31, 2017 11:01 am
Just thought I would share a project I have completed using QCAD / CAM, basically it's for foam inserts to hold electronic components. The inserts then fit into aluminum flight cases.
CNC CAD - CAM.jpg (149.17 KiB) Viewed 6286 times
Re: Project with QCAD / CAM
Post by Husky » Thu Aug 31, 2017 3:39 pm
Very nice!
Dreamaker
Post by Dreamaker » Thu Aug 31, 2017 4:57 pm
Nice job. What are you using for a tool/cutter, and what is your spindle speed and feed? Very nice!
Clive
Post by Clive » Thu Aug 31, 2017 6:34 pm
Thanks Husky, much appreciated :) .
Dan,
I work in mm so:
cutter - straight 4 fluted 12.7mm dia.
spindle speed -16000 rpm
feed rate - 1000
plunge rate 500
This was milled from polyether polyurethane packing foam. It milled out reasonably well considering this was profile cut and not pocketed, I think when Andrew adds support for pocketing it will up the game big time 8)
Normally I work with wood and often acrylic and card stock too.
I see your last examples are from acrylic - I presume this must be cast acrylic? normally I laser cut acrylic. What feeds & speeds did you use for the acrylic?
Thanks, Clive
Dreamaker
Post by Dreamaker » Thu Aug 31, 2017 7:26 pm
The acrylic is poly-carbonate, I use a 3mm, two flute flat nose cutter. Spindle speed is a little over 9100rpm, feed is 500 with multi pass cuts for 9.5mm Polycarb. plunge is 250.
Why does you cutter appear red?
J-J
Moderator
Post by J-J » Thu Aug 31, 2017 7:34 pm
Very professional!
What do you use for the cutter?
JJ Win7 pro-64
Clive
Post by Clive » Thu Aug 31, 2017 8:35 pm
Thanks for the info on the polycarb.
CMT Orange tools via a uk supplier.
J-J, thanks, it needs to be professional, this is for a professional company :wink: .
