Starting Tools
Starting Tools
Post by andrew » Fri Jun 23, 2017 8:18 am
In QCAD, there are various ways to start a tool such as the tool to draw lines.
- To browse through the various CAD tools available, you can use the CAD toolbar at the left:
Screen Shot 2017-06-23 at 09.05.56.png (95.82 KiB) Viewed 11240 times
- Alternatively, you can close the CAD toolbar (View > Toolbars and Widgets > Toolbars > CAD Tools) and use the tool matrix instead (View > Toolbars and Widgets > Widgets > Tool Matrix). The tool matrix shows all tools in one flat matrix. The filter input field at the top allows you to only show tools based on a keyword ("arc" will show all arc related tools).
Screen Shot 2017-06-23 at 09.09.09.png (209.88 KiB) Viewed 11240 times
- If you prefer to browse tools through a text interface, you can use the standard menu at the top, as in most applications (e.g. Draw > Line > Line from 2 Points).
Screen Shot 2017-06-23 at 09.19.05.png (138.11 KiB) Viewed 11239 times
- If you know the command that triggers a tool, you can also use the QCAD command line at the bottom. To move the keyboard focus to the command line, click into it with your mouse or hit the space key. For example hit space and then enter the command "line" into the QCAD command line widget and hit the enter key. QCAD launches the line tool and you can start drawing lines. In the command line you can also enter or paste coordinates or a whole list of coordinates.
Screen Shot 2017-06-23 at 09.13.48.png (34.33 KiB) Viewed 11240 times
- The fastest and most efficient way to start tools in QCAD is by using the two or three letter key codes provided for almost every tool. Make sure that the command line does NOT have the keyboard focus or press the Escape key to remove focus from the command line. Now press the L key, followed by the I key to start drawing lines. Press Escape when you are done. Press C followed by I to draw circles, etc. You can find all key codes listed in the menu or in the tooltips provided in the CAD toolbar or tool matrix.
