Open Source Nesting
John Hyslop
Re: Open Source Nesting
Post by John Hyslop » Sun Mar 08, 2020 2:33 am
Hi Husky
Just tested with quite a few parts and it worked great, apart from this file, somehow it seems to of reversed some arcs? any idea what might be going on... it's in metric, was going to nest on a 2400x1200mm sheet...see picture and attached file..
Shape-01 - Rev B.svg
(7.82 KiB) Downloaded 133 times
Post by Husky » Sun Mar 08, 2020 6:54 am
... somehow it seems to of reversed some arcs? any idea what might be going on...
I'm sorry, I have no idea. :(
Post by CVH » Sun Mar 08, 2020 8:26 am
Pls, attach your files.
That would not be the first issue with SVG.
QCADpro 3.24.3.10 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
John Hyslop
Post by John Hyslop » Sun Mar 08, 2020 9:40 am
Hi Husky
I did attach the svg file? did you want the dxf too?
See attached...
Cheers
John
Shape-01 - Rev B.dxf
(374.58 KiB) Downloaded 136 times
Post by CVH » Sun Mar 08, 2020 5:16 pm
Rather all arcs look to be reversed in your screengrab.
The dxf and the re-imported svg consist both out of 53 non-reversed arcs.
Setting something else as 'White' and 'Default' for the lines:
Looks ok in a browser.
Opens ok in Inkscape.
So it is a Deepnest issue.
Did you try reversing the arcs, or conbined to a polyline?
Post by Husky » Mon Mar 09, 2020 7:16 am
Hi John,
Hi Husky
Nope - I haven't ask for the dxf :wink:
John Hyslop
Post by John Hyslop » Mon Mar 09, 2020 10:34 am
Hi Both
I reckon it's the nesting program too..
I also opened up svg in inkscape but only displayed rectangle but AutoCAD opened the dxf with no problems..
CVH yes same issue with polylines...
Silly me rectangle was white on white saved from inkscape as DXF and all arcs are ok..👌
Cheers
John
John Hyslop
Post by John Hyslop » Mon Mar 09, 2020 11:51 am
Hi Husky
Deepnest cannot process SVG files correctly every one I've tried so far fails all arcs are reversed..the pc I'm using is offline..I bet it will work while online..pity it looked very promising..
Cheers
John
Post by Husky » Tue Mar 10, 2020 5:59 pm
You lost! e_surprised Online / offline does not matter. SVG fails in both scenarios. Good to know ...
John Hyslop
Post by John Hyslop » Wed Mar 11, 2020 12:44 am
Damn...there is always qcad/cam at a small investment 😁
John Hyslop
Post by John Hyslop » Thu Mar 12, 2020 4:49 am
Hi Husky
I made this for you... it will save you a fortune on internet cables LOL
Works in Windows up to 10, not sure about Linux....
Cheers
John
PS If you don't want it delete this post :-)
Net-On-Off.zip
(217.86 KiB) Downloaded 124 times
Network On & Off.jpg (7.18 KiB) Viewed 5783 times
Post by CVH » Thu Mar 12, 2020 12:35 pm
Deepnest is what they call 'abandonware'.
Jack Qiao (Jack000) never did surface again after 2018.
https://github.com/Jack000
http://jack.works/
There is a fork with later commits:
https://github.com/InfernoEmbedded/Deepnest
Deepnest is based on SVGnest from the same author.
Last commit there is from april 2019.
Deepnest and SVGnest topics are spread over many sites and pages.
I did came across some demands and commits about arcs but not as we are experiencing.
Found a mail address: jak000 at gmail.com
(had to chop that address or the msg failed as spam)
Many are trying to reach him.
Pitty, it looked promising.
John Hyslop
Post by John Hyslop » Sat Mar 14, 2020 1:20 am
Hi CVH
Interesting.. thanks
Cheers
John
