sto ricominciando ad usare qcad, ma sto riscontrando questo problema:
come potete vedere dall'immagine allegata i tooltips sono illeggibili.
Uso ubuntumate 15.04 ho provato a cambiare tema.. ho cercato nei file di configurazione di qcad ma niente..
ciao
g
tooltips non leggibili
- tooltip.png (48.52 KiB) Viewed 21114 times
Re: tooltips non leggibili
come sospettavo è un problema di MATE con Ubuntu non derivata non ci sono problemi
g
g
Ciao, hai questo funziona correttamente ora?
Hi, have you got this working correctly now?
not in ubuntumate bat it working correctly in ubuntu with unity. So I think depend from Marco (mate window manager)
Possible solutions:
- start QCAD with a different Qt style:
./qcad -style gtk
- Change your theme to the Gnome default theme in the system preferences
- Try to fix the current theme, you can find some more information about this at https://bugs.launchpad.net/ubuntu/+sour ... ug/1332100
- Configure the appearance of all Qt applications using qt-config (see https://www.youtube.com/watch?v=M2W_7YsUiGE)
./qcad -style gtk
I have the same issue described in this post
I am using
QCAD Version: 3.14.3.0 (3.14.3)
MATE Desktop Environment 1.12.1
Ubuntu Release 16.04 LTS (Xenial Xerus) 32-bit
I have been able to fix the issue using Andrews suggested solution
"- Configure the appearance of all Qt applications using qt-config (see https://www.youtube.com/watch?v=M2W_7YsUiGE)"
Thank you Andrew
To access Qt under Mate desktop go System/Preferences/Look and Feel/Qt 4 Settings
Default settings found
GUI Style = GTK+
Tooltip Colour = White
Fonts= Medium Italic
I am using
Thank you Andrew
GUI Style = GTK+
