Print preview stays on
Brass Monkey
Post by Brass Monkey » Wed Nov 23, 2011 1:16 pm
Version:
3.0 RC1
Date:
Oct 31 2011
Qt Version:
4.7.3
Edition:
Full Version
When given the "print" command from the normal drawing environment, Qcad goes to print preview. However nothing will turn the print preview off from here except closing the file and reopening it.
selecting "print preview" from the regular drawing mode allows the preview to be turned off when it's finished with.
Bug, or something I'm doing wrong?
Post by andrew » Wed Nov 23, 2011 1:35 pm
Bug:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=403
Note that closing the print preview with the close button in the options tool bar should work in any case.
