Andrew
I have been extremely impressed with QCAD as a very cost effective and simple platform with which to enter the CAD market. It is very quick to load, simple to use and remarkably versatile once you get to know the wrinkles.
Here are some of the things that could be improved and hopefully will be incorporated into version 3, which I will definitely purchase when it is ready:
1. Trim and line extension tools needs to be on ribbon tool bar.
2. JPEG import function.
3. Proper DXF interface with AutoCAD including text.
4. Simplify text fonts and allow setting in column width.
5. Line length and parallel measuring tool like Sketchup.
Some suggestions for incorporation into QCAD 3
Re: Some suggestions for incorporation into QCAD 3
A jpeg import function would be so useful, and yeah, qcad is really impressive.
Hi and welcomeabovabum wrote:A jpeg import function would be so useful, and yeah, qcad is really impressive.
You can add feature requests here:
http://www.ribbonsoft.com/bugtracker/
You will need to register to add bug reports/feature requests.
In QCAD 3 you can use the 'Insert Bitmap' tool to insert jpeg, bmp, gif, jpg, png, tiff, tif files.
- Insert Bitmap tool.jpg (31.31 KiB) Viewed 29589 times
