Dimensions missing
LHarv
Dimensions missing
Post by LHarv » Wed May 12, 2010 10:53 pm
When I add a dimension no arrows appear and the dimension does not show. Also, I am having trouble changing the cursor position display to not be in mm.
Re: Dimensions missing
Post by andrew » Wed May 12, 2010 10:58 pm
LHarv wrote:When I add a dimension no arrows appear and the dimension does not show.
Most likely they are too small. See also FAQ at:
http://www.ribbonsoft.com/qcad_doc_faq.html#11
LHarv wrote:Also, I am having trouble changing the cursor position display to not be in mm.
You can set up the drawing unit in the drawing preferences: Menu 'Edit' - 'Current drawing preferences'. The coordinate display is in the same unit as your drawing.
