Clip to rectangle problem ...
Post by Husky » Wed Nov 27, 2013 9:34 pm
I'm trying right now to use the "Clip to rectangle / clip to area tool.
Unexpected I have problems to define the size of an area - but not in all parts of the drawing and I don't know why!
"Big area" = impossible - the left mouse click is not accepted
"Small area" ... works. Why??????????
Any Idea on this?
Re: Clip to rectangle problem ...
Post by andrew » Thu Nov 28, 2013 11:54 am
Thanks for the report.
Could you attach or e-mail the DXF file for testing? Thanks.
Post by Clive » Thu Nov 28, 2013 12:53 pm
Yes, I've noticed this too. It seems to happen when selecting parts of a drawing that contain Circles.
Works fine for Arc and Ellipses, but Circles no good. Check my simple test.
Clip to Rectangle test.dxf
(79.07 KiB) Downloaded 642 times
Post by andrew » Thu Nov 28, 2013 1:01 pm
Thanks Clive. I can reproduce that behavior and files a report at:
http://www.qcad.org/bugtracker/index.ph ... ask_id=977
Post by Clive » Thu Nov 28, 2013 2:16 pm
andrew wrote:Thanks Clive. I can reproduce that behavior and files a report at:
No problem, glad you've sorted it out :wink:
@Husky, it will be good to test this with the forthcoming new release 8)
Post by Husky » Thu Nov 28, 2013 7:49 pm
clive wrote:@Husky, it will be good to test this with the forthcoming new release 8)
That's for sure ... :lol: :lol: :lol:
Post by Clive » Thu Dec 05, 2013 1:18 pm
Hey Husky check it out, this seems to be fixed now in 3.4.4 :wink:
Post by Husky » Thu Dec 05, 2013 7:36 pm
clive wrote:Hey Husky check it out, this seems to be fixed now in 3.4.4 :wink:
Yep - now it works like a charm. Thank you Andrew!
