Use of "Substitute Fonts" question ...
Post by Husky » Thu Nov 21, 2013 9:57 pm
Hi guys,
do I always have to save and reload my drawing after the use of the "Substitute Fonts" tool to see the outcome?
Is there a more convenient way to work with this tool? e_confused
Re: Use of "Substitute Fonts" question ...
Post by andrew » Thu Nov 21, 2013 10:06 pm
I cannot reproduce that behavior here. Changes should indeed be visible immediately after using this tool. Do you have an example drawing / use case? Thanks.
Post by Husky » Thu Nov 21, 2013 10:53 pm
andrew wrote:Changes should indeed be visible immediately after using this tool.
Unfortunately .... not!
Screen-shots with "extreme font" for demonstration - but this behavior is the same with all tested fonts.
start tool "Substitute Fonts",
Change the text font - confirm with Ok - no changes visible in the drawing.
Start again - information is correct - it should be the "Keystroke" Font - but I can't see it ...
... cancel the tool - Save/reload the drawing - now I have the changes visible!
And yep - it happened in XP32 :wink:
Edit: I used a new drawing for the test - no inherited waste! :lol:
J-J
Post by J-J » Fri Nov 22, 2013 7:55 am
It works all right with win7....
Husky,you are due for a system upgrade !
JJ Win7 pro-64
Post by Husky » Fri Nov 22, 2013 8:47 am
J-J wrote:Husky,you are due for a system upgrade !
Yep - I know! But I been told by QCAD that it still will work with XP/32 :lol:
