Free Hatch Patterns
- Premier Member
Re: Free Hatch Patterns
Hi All
Designs by Husky Cheers
John
John
- Premier Member
Me Again
Design by Husky Cheers
John
John
- Premier Member
Hi
John
John
- Premier Member
John
- Premier Member
...I'll do more later...
John
John
- Premier Member
Good Afternoon
John
John
- Premier Member
Hi All
John
John
- Premier Member
Hi All
I was playing around with my "Basic Hatch Pattern Tool" & remembered you could do a Basket Weave Pattern
It's a common Brick Paving Pattern, All you need to do is set the Width & Height the same in my program and
tick the "Double Weave" box that's it
It can be downloaded at https://www.qcad.org/rsforum/viewtopic. ... =15#p33566
Pattern Created is a 12x6 Brick
. Cheers
John
. Cheers
John
- Premier Member
Hi All
Wishing everybody best wishes for the festive season...
I thought I'd sneak in one more pattern before the end of the year..
An addition to my lattice patterns
Cheers
John
Cheers
John
- Premier Member
Hi All
I had a panel that required a honeycomb grille pattern, so I thought it would be easier to create a pattern
explode it and trim off the excess, it worked a treat so I'm sharing it with you all... Top panel in the picture is the
job I did today in Qcad..
Cheers
John Hyslop
Cheers
John Hyslop
- Premier Member
Hi All
The above pattern can now be created any size and with any gap you like... or no gap
My Basic Hatch Pattern Tool now includes an editable honeycomb pattern it can be downloaded here:-
https://www.qcad.org/rsforum/viewtopic. ... 4&start=15
Cheers
John Hyslop
Cheers
John Hyslop
- Premier Member
Hi All
I've made 2 new patterns below.. Please note some of my patterns can be used for decorative panels
eg Corten "rusty looking metal" screens etc...simply scale pattern explode and trim to suit.. enjoy..
Cheers
John
Cheers
John
- Premier Member
Another Arrow Pattern
Cheers
John Hyslop
Cheers
John Hyslop
- Premier Member
Hi All
1st a big thank you to Husky for this suggestion and also help on info supplied in PDF included in zip file..
Cheers
John Hyslop
Fixed Typo in PDF file "Downloaded 4 times"
PS These of coarse are only some samples of scaling , you can scale any size you like
Cheers
John Hyslop
- Premier Member
Hi All
Another Pattern Taking Scaling into Consideration...
I left a small gap between the rows so the pattern can easily be aligned with the cavity without showing the next row..
Consider Using LineType "Batting" , Never Knew This Existed. .. I'll Leave This One Here Anyway
Cheers
John Hyslop
Cheers
John Hyslop
