Download Documenation
cmh31909
Post by cmh31909 » Thu Nov 28, 2019 2:13 am
Is there a way to get a copy of the documentation installed to my local drive so that I can reference it when not connected to the Internet?
When I use Help->Documentation in the program, it starts a web browser and goes to: https://qcad.org/doc/qcad/latest/reference/en/
Most of the time where I am using the package, I will not have reliable Internet connectivity, so it would be really nice to be able to download and install this on my local drive.
Thanks,
Carlton
Re: Download Documenation
Post by Husky » Thu Nov 28, 2019 3:29 am
Go to the end of the post in the link - would that pdf serve your needs?
viewtopic.php?f=34&t=5960&p=22250&hilit=manual#p22250
Post by andrew » Thu Nov 28, 2019 8:21 am
QCAD Professional (as well as QCAD/CAM) comes with an integrated manual which can be viewed offline and has a search tool and an index. If a browser opens, you are using the free QCAD CE. I'll move this to the appropriate QCAD CE forum.
cmh31909
Post by cmh31909 » Thu Nov 28, 2019 4:46 pm
I'm using the Trial mode, which I assumed was fully functional until the trial period expires.
I looked in the install directory for the application and did not see any documentation files.
cmh31909
Post by cmh31909 » Thu Nov 28, 2019 4:48 pm
That is certainly better than nothing, thank you for the link!
