sketchup C API for import/export ?
turtle
Post by turtle » Mon Nov 11, 2019 3:22 am
Greetings all is it possible to use the SketchUp C API to import / export files from sketchup?
http://extensions.sketchup.com/develope ... index.html
Comments based on Version: 3.23 unless otherwise noted.
Re: sketchup C API for import/export ?
Post by andrew » Mon Nov 11, 2019 9:23 am
Yes, I don't see why not. You'd have to create a QCAD plugin that links in the SketchUp API and import these files as (2D) QCAD entities.
