[SOLVED] Qcad vs QcadPro Layers
Post by CVH » Thu Oct 10, 2019 6:23 am
Andrew,
I remember that one of the reasons I switched to Pro was the Layer functionality.
Writing a script that adds layers or sub layers I wonder if this still holds true.
Is the Layer functionality still turned off after some time for non Pro?
If so, how can a script detect this?
Thanks,
Re: Qcad vs QcadPro Layers
Post by andrew » Thu Oct 10, 2019 7:47 pm
Layers are available in both QCAD CE and QCAD Pro. Hierarchical layers and some advanced layer properties are only available in QCAD Pro.
Post by CVH » Thu Oct 10, 2019 8:06 pm
CE is same as trial?
Post by CVH » Thu Oct 10, 2019 8:08 pm
Hierarchical layers ..... are only available in QCAD Pro.
Sorry, the answer was there.
How to know as script?
Post by andrew » Thu Oct 10, 2019 8:11 pm
You can detect if one of the QCAD Pro plugins is loaded:
if (hasPlugin("PROTOOLS")) {
    // QCAD Pro
else {
    // QCAD CE
Post by CVH » Thu Oct 10, 2019 8:23 pm
Thanks,
Will keep this in mind for a later release.
I am preparing to upload FlexPainter beta v0.41
Post by Husky » Fri Oct 11, 2019 3:30 am
Writing a script that adds layers or sub layers ...
Just curious: What is the benefit of that?
Post by CVH » Fri Oct 11, 2019 6:53 am
In the near future FlexPainter will have the option to cast on
the active layer or on a sub-layer of the base entity.
The script has to know if it can create sub-layers.
So it can enable or disable that option.
Thanks for the interest,
Post by Husky » Fri Oct 11, 2019 7:26 am
Thanks.
Post by andrew » Fri Oct 11, 2019 7:56 am
There's actually no such thing as sub-layers in DXF. QCAD simply names a parent layer "ParentLayer" and a sub-layer of it "ParentLayer ... MySubLayer". " ... " is defined in RLayer.getHierarchySeparator().
So if your script creates layers called "ParentLayer ... MySubLayer" they will show up as sublayer hierarchy in QCAD Pro and as "ParentLayer ... MySubLayer" in QCAD CE.
Post by CVH » Fri Oct 11, 2019 8:17 am
I did understand that.
I only don't want to cross the pro boundary as intended by the choise of package.
We probably could circumvent all pro features.
