Hello
How do you translate an interface (for example: OrthogonalProjections.ui) from English to Italian or another language
Interface translation *.ui
- Full Member
- Location: http://creativitainformaticart.altervista.org
Re: Interface translation *.ui
You can use Qt tools to create a TS (translation source file):
1. lupdate File.ui -ts File_it.ts
2. Translate file File_it.ts (e.g. using Qt Linguist)
3. lrelease File_it.ts
4. Load translation file in source code:
var translator = new QTranslator(qApp);
if (translator.load("File_it", "path/to/translationfile")) {
QCoreApplication.installTranslator(translator);
- Full Member
thank you
