one-click erase (ER)
Krischu
Senior Member
Post by Krischu » Sun Jul 07, 2019 9:46 am
Since I'm new to Qcad I may not have found all of the possible protocols. But what I find tedious at the moment is the way how to delete entities.
You have to select an entity and type ER or click the india rubber.
Is there a way to be in ER-Mode and click the object piecewise one after another?
Christoph
Re: one-click erase (ER)
Post by Husky » Sun Jul 07, 2019 5:46 pm
There are different ways to collect a selection and delete them all together.
e.g. if you are on Win try to collect multiple single entity: Press and hold the SHIFT key on your Keyboard, select multiple entities one by one with your mouse pointer, delete them all together with the delete key on your keyboard.
Krischu
Senior Member
Post by Krischu » Mon Jul 08, 2019 7:07 am
Thanks. That's what I ended up with (I'm on macOS). SHIFT-Click protocol works there as well (of course).
Christoph
