I'm converting a DGN file to SVG using QCAD command like tool.
Qcad Version: 3.16.5.0 (3.16.5)
I see that result SVG file contains an XML comment sections for each text label in source file.
For example, a DGN text label "400A" will appear in SVG file as comment like: "<!-- Text: 400A -->"
My issue is: when DGN text label contains two dashes "--", after conversion SVG file will contain this: "<!-- Text: -- -->"
This conflicts with W3C XML standard: https://www.w3.org/TR/2008/REC-xml-2008 ... c-comments, which prohibits placing two dashes into an comment.
My question is: how can I avoid such situation? Is there some adjustments to a js file during conversion, or any other ways to get rid of two dashed into XML comment?
Thanks.
DGN -> SVG conversion issue
Re: DGN -> SVG conversion issue
I cannot think of a straightforward workaround.
Bug report under:
https://qcad.org/bugtracker/index.php?d ... sk_id=1883
Bug report under:
- Newbie Member
Hello, andrew
Thank you for logging in a bug.
I see that the bug is in status Closed with resolution Fixed. Just to be clear: does it mean that the issue is fixed in 3.22.0 version? Or it will fixed in next releases?
It's fixed in the sources. The fix will be available in the next release (or development snapshot).
- Newbie Member
I'm asking because new versions can not convert DGN to SVG (details https://qcad.org/rsforum/viewtopic.php?f=95&t=6141) and I have to use version 3.16.5.
Could you provide a backport to 3.16.5?
Or how can I apply the fix on 3.16.15?
Unfortunately, we cannot provide a backport for 3.16.5. If you are stuck with that version, I'd recommend to post-process the SVG and remove or fix the comments, for example using a simple batch or bash script.
- Newbie Member
Ok, thank you
