How to distribute a c++ plugin
ezm
Post by ezm » Wed Mar 27, 2019 4:10 pm
Hi Andrew,
I have developed a c++ plugin in QCAD community edition. Can you let me know how to distribute the plugin?
Re: How to distribute a c++ plugin
Post by andrew » Wed Mar 27, 2019 4:23 pm
You can simply bundle the plugin with your package / installer in the "plugins" directory.
ezm
Post by ezm » Wed Apr 24, 2019 2:49 pm
Thanks Andrew.
But when my plugin contains QSharedPointer, when I load the dll it says The specified procedure could not be found.
I am using Qt 5.5.1 with MSVC 2013. QCAD version 3.22.0
QCAD plugin error.PNG (53.41 KiB) Viewed 3610 times
Post by andrew » Fri Apr 26, 2019 1:49 pm
This is a Qt related problem.
You can set the environment variable QT_DEBUG_PLUGINS=1 to output more information when starting QCAD.
Also try to Google for "qt plugin the specified procedure could not be found".
ezm
Post by ezm » Mon Apr 29, 2019 5:05 pm
Ok, thanks !
