Can circles round points be removed
Re: Can circles round points be removed
Post by andrew » Fri Mar 15, 2019 11:00 am
You are very likely trying to draw on an invisible layer.
Step by step:
1. View > Layer List
2. Move your mouse cursor to the location where layer "Holes_Wires" is shown on the name of the layer:
Screen Shot 2019-03-15 at 09.42.33.png (31.83 KiB) Viewed 456 times
3. Click the left mouse button. The layer should now be highlighted with a blue background as shown here:
Screen Shot 2019-03-15 at 09.42.36.png (31.55 KiB) Viewed 456 times
This means that layer "Holes_Wires" is now the active layer. That is the layer you are drawing on and the layer that must be visible and unlocked. In your drawing that is the case.
Since all other layers in your drawing are invisible, this is probably the layer you want to place the circles on and I'd recommend to try that before trying anything else since that is the easiest way and does not involve changing any layers.
If the above layer list looks any different on your end, please post a screenshot (there are various preferences involved and you might have set up things differently on your end).
About the error message: QCAD deliberately prevents you from drawing "blind" on invisible layers since this would mean you'd get something you didn't see rather then the usual what you see is what you get.
crowhurst
Post by crowhurst » Fri Mar 15, 2019 4:09 pm
Many thanks, Andrew. I'll get at it this afternoon.
Nick.
crowhurst
Post by crowhurst » Fri Mar 15, 2019 5:53 pm
You've solved it, thank you. Highlighting the layer in blue did the trick. Thanks for sticking with me.
Nick.
crowhurst
Post by crowhurst » Sun Jun 09, 2019 4:58 pm
Three months ago this worked perfectly, but I've tried with the attached file the last two days to convert the 328 points to 0.75 mm radius circles, without success. I'd be very grateful for some help here.
Nick.
test file for Qcad forum.dxf
(3.45 MiB) Downloaded 21 times
Post by Husky » Sun Jun 09, 2019 6:16 pm
It looks like there is in the same position a point with two circle (R 0.375 and R 0.75). I assume you only need the R 0.75 circle, correct?
crowhurst
Post by crowhurst » Sun Jun 09, 2019 6:34 pm
Well found! I was relying on the Property Editor, which identified each item only as a point. I didn't think to zoom that far into a single point. Can you recommend the way ahead? Selection filter and delete all circles, hoping there aren't any circles which shouldn't be deleted, then start again with the 328 points? Yes, I just need the R 0.75 circles.
Many thanks. Nick
Post by Husky » Sun Jun 09, 2019 6:51 pm
Use the Selection Filter to find and delete the unwanted entities.
Launch the Selection Filter and search for points. Select them. If you have find 328 point (check in the property manager) then you are on the safe side. Delete the points.
Use again the Selection Filter to find the R 0.75 circle (D 1.5). Same game - if you find 328 circle you are on the safe side. Delete them. :wink:
crowhurst
Post by crowhurst » Sun Jun 09, 2019 6:54 pm
Excellent. I'm most grateful.
Nick
