Dark Theme in Ubuntu
dfriasb
Post by dfriasb » Fri Mar 08, 2019 3:41 pm
Dear all,
I just installed QCAD 3.22.0 in an Ubuntu 18.04 machine an it's not looking as nice as before, in my opinion. Some check boxes are also not visible, as you can see in the screenshot attached here. Default theme is looking fine like before.
Thanks! David.
Screenshot from 2019-03-08 15-43-00.png (139.32 KiB) Viewed 1015 times
Screenshot from 2019-03-08 15-34-33.png (55.03 KiB) Viewed 1017 times
Re: Dark Theme in Ubuntu
Post by andrew » Fri Mar 08, 2019 5:29 pm
This needs a lot more work or possibly a separate theme under Linux and is currently optimized for macOS / Windows:
Screen Shot 2019-03-08 at 16.25.58.png (105.38 KiB) Viewed 1011 times
dfriasb
Post by dfriasb » Fri Mar 08, 2019 7:05 pm
Ok! No problem, meanwhile I'm using default's. Thanks a lot!
lphilpot
Post by lphilpot » Sat Mar 09, 2019 12:56 am
For what it's worth, I recently inline-upgraded my Xubuntu 16.04 desktop to 18.04.2. I'm running the Greybird desktop theme and the Xfce 4.6 Default window manager theme, along with the QCAD dark theme. So far, so good as far as QCAD (3.21.3.0) is concerned:
QCAD is build on QT, which IME seems to be more resilient to environment changes than GTK. I've had to select my desktop theme carefully, since GTK3 (ick) no longer plays nicely with many older GTK apps and there can be huge UI artifacts with many older themes.
Len
dfriasb
Post by dfriasb » Sat Mar 09, 2019 10:07 am
Thanks lphilpot. My problems with dark theme started on 3.22 QCAD Pro version. Version 3.21 was looking good on my Ubuntu 18.04 machine. Did you try last version of QCAD? Dark theme was modified on it: https://qcad.org/en/changelog
lphilpot
Post by lphilpot » Sat Mar 09, 2019 1:51 pm
No I've not tried that version. My pro upgrade entitlement expired in December and I've not upgraded since. However now that you mention it, I think I tried a newer snapshot late last year with the same results you're getting. So I went back to my version.
Len
