I've recently re-installed Windows 10 and afterwards found that Print Preview Pan didn't work. I restarted QCAD and it did work, but has bow stopped working again. Restarting doesn't fix it.
Windows 10
Version 3.21.3.0 (3.21.3)
DXF attached
Print Preview Pan not working
- Junior Member
Re: Print Preview Pan not working
Works for me. However - can you test the modified drawing and tell us if the issue persist or not.
- Junior Member
Both versions now pan!! But thank you...
- Junior Member
Still occasionally refuses to pan....
- Junior Member
Still having problems with pan not working in print preview.
QCAD 3.21.3.0 (3.21.3)
Windows 10 Home 1903 18368.592
- dressing 002.dxf
- (319.23 KiB) Downloaded 354 times
Tested again with the same QCAD version - works still like a charm.LouiseSJPP wrote: ↑Wed Feb 05, 2020 5:25 pmStill having problems with pan not working in print preview.
Just to be on the same page: Do you try to pan the drawing or move the Paper position? Please elaborate precisely how you launch and use the tool. Thanks.
- Junior Member
It's an intermittent problem. Sometimes closing QCAD and relaunching clears it.
I launch QCAD from the W10 start menu. I usually scroll to Recent Files to find the one I want, or begin a New File.
Usually, when wanting to Print, I open the Print Preview, scale the drawing down until i can see the white paper sheet on top of the greyed out drawing, then use the scale and portrait / landscape controls to adjust the paper. Then I hit the Pan button and try to grab the paper and drag it to where I want it.
When it won't work, the drag is unresponsive.
