Wanted a way to define a spline
Kuma
Post by Kuma » Fri Jan 25, 2019 5:20 am
Is it possible to create a spline with predefined length and control its curve?
Re: Wanted a way to define a spline
Post by andrew » Fri Jan 25, 2019 10:04 am
No.
You can use the tool Modify > Divide to divide a spline at a given length using Snap > Distance to set the dividing point.
Kuma
Post by Kuma » Sat Jan 26, 2019 5:31 am
Thank you for your reply it is very helpful, are there any algorithm to calculate the control point if we knew the length of the spline?
Return to “Chat”
