hi,
qcad-3.21.3-pro-linux-x86_32 dxf-files from you herself may be 7 Years ago downloaded ribbonsoft url
I've change to another layer something e.g.nut (pict 1). In early QCAD-version they are no problem.
then i select all to change and make dubble klick in layer red. (pict 2)
result is changed only line-thickness (pict 3) no line typ, no color,
how to get a result in my mind? What get wrong in my way?
Thanks Kuhcadler
changing dxf-files at whole
- Pict 3.png (48.51 KiB) Viewed 2571 times
- Pict 2.png (38.32 KiB) Viewed 2571 times
- Pict 1.png (29.02 KiB) Viewed 2571 times
Re: changing dxf-files at whole
You can check in the property editor (View > Property Editor) if these entities have their attributes set to "By Layer" or not. If not, the layer has no influence on the attributes. You might want to change those attributes to "By Layer" in this case.
As always, if you cannot solve the problem, please attach the DXF file in question.
It'a also not quite clear from your screenshots if you have inserted the symbol as a block and then moved that block reference to layer "red" or if you have exploded the block first. If you didn't explode, there's more to keep in mind, see viewtopic.php?f=47&t=3121.
