set default postprocessor
jamby
Post by jamby » Sun Oct 07, 2018 7:30 pm
I am wondering if there is a way to set the default post processor that is in a new file when opened?
Jim
Re: set default postprocessor
Post by andrew » Mon Oct 08, 2018 9:44 am
Yes:
Edit > Application Preferences > CAM > CAM Export > Configuration used for new drawings
jamby
Post by jamby » Mon Oct 08, 2018 4:33 pm
Thank you
Jim
Return to “QCAD/CAM”
