generating gear part
J-J
Re: generating gear part
Post by J-J » Sat Dec 31, 2016 10:18 pm
tried that, but not sure they'd work properly. This is experimental I guess!
Happy New Year
gear set.jpg (139.13 KiB) Viewed 4959 times
JJ
Post by Husky » Wed Jan 04, 2017 8:45 pm
J-J wrote:tried that, but not sure they'd work properly. This is experimental I guess!
Happy New Year
I guess you are right! Thanks for the test - looks like it was a kind of fiddling to use it with a m=2.5.
I work with an extern Gear Generator and would like to see it equivalent (at least) replaced by QCAD. It looks like I have a
reason to be optimistic ... :wink:
Happy New Year!
caigner
Post by caigner » Mon Sep 24, 2018 9:29 am
Two gears mesh if the module is the same.
It would help if we could enter the module instead of the pitch diameter. Then we would always get gears that work together.
QCAD Pro on Gentoo Linux
