[solved] rectangle cutting inside
cki61
Post by cki61 » Mon Apr 23, 2018 6:58 pm
Hi Andrew,
I created 2 rectangles by new:shapemenue:rectangle, please see appended image.
I created a polyline out of both rectangles. The right one has an additional knot in the middle of the lower line.
Now I created a toolpath for both to cut at the inner side.
At the left rectangle has a cut into the material at the beginning and at the end of the cut. The right one is ok.
Can you give me a hint why the algorythm sees a difference between the rectangles?
Best regards,
Christof
Re: rectangle cutting inside
Post by andrew » Mon Apr 23, 2018 8:20 pm
QCAD/CAM starts the toolpath at the start point of the polyline. If this is a corner of an inside profile and a lead in/out is used, there is no possible toolpath without cutting into the workpiece (left side). To create a meaningful toolpath, the start point has to be chosen to be somewhere in the middle of a side for inside profiles (right).
Please refer also to the QCAD/CAM tutorial at:
https://qcad.org/doc/qcadcam/QCADCAM_Tutorial_en.pdf
cki61
Post by cki61 » Mon Apr 23, 2018 8:59 pm
thanks for your answer,
Best Regards,
Christof
Return to “QCAD/CAM”
