Printing of dotted/dashed lines
Locked
pavneet
Post by pavneet » Sun Mar 23, 2008 2:59 pm
I am new to QCad, but have quickly fallen in love with it. I began trying it out a week ago. I am using it to design cabinetry and millwork. I seem to have a bit of a problem getting dotted and dashed lines to print properly. On screen they appear fine, but when printing they appear solid or as near solid as to be indistinguishable from solid.
I am running QCad on Ubuntu Gutsy and printing out to both a B&W laser (HP LJ1020) and a colour InkJet (HP T65) in both cases on Letter paper.
Any help you can offer would be most appreciated.
Many thanks.
pavneet
Post by pavneet » Mon Mar 31, 2008 1:51 pm
Should I assume that no one else has this problem? I tried to upload the .ps file but the suggested image repository site doesn't accept this as a file type. The .jpg does show dotted/dashed lines rendered properly, but of course this does not provide a resolution that is suitable for printing.
Scale for me is 1" with Format being specified as "Fractions".
Can anyone give me some insight as to what I may be doing differently than others?
Many thanks.
Post by andrew » Mon Mar 31, 2008 1:54 pm
It could be that your line widths are very small. Since QCad scales the line pattern with the line width, a dotted line might appear almost solid if it is very thin.
pavneet
Post by pavneet » Tue Apr 01, 2008 10:54 pm
Thanks Andrew. That took care of it. I had 0.00mm line widths, which I changed in each layer to 0.13mm (ISO). I had just left it as 0.00mm because when printing in colour, the line width was crisper, but, of course, the dot/dash didn't work as desired :wink:
Cheers.
Gooserider
Post by Gooserider » Tue Aug 25, 2009 6:15 am
I am having the opposite problem - most of my line widths are set to 1.0mm(ISO).
The solid lines look fine, but the dotted lines have their dots so far apart as to be hard to even see they are there, let alone where they go.
What is strange is that the lines initially looked fine when I drew them, and then suddenly changed the dot size / spacing. The dotted lines went to the larger spacing and the dash and dash-dot lines also became hard to recognize.
I have the drawing size set to "US Letter" in portrait orientation, and each line type is on it's own layer.
I have tried playing with the line properties, and found that going with the small variants on each type helped, and so did going to a thinner line size, but I'd really like to use a thicker line on the drawing. Is there any way to adjust the dot / dash size and spacing without changing the line size?
Gooserider
beginner
Re: Printing of dotted/dashed lines
Post by andrew » Mon Jun 06, 2016 3:12 pm
dfriasb: your new question about QCAD 3 has been split into a new topic in the appropriate QCAD 3 forum at:
http://www.qcad.org/rsforum/viewtopic.php?f=33&t=4262
Locked
Return to “QCAD 2.1/2.2 Troubleshooting and Problems”
