By default, the line type pattern is applied to each segment of a polyline individually (left).
Especially for polylines with many small segments this can result in solid polylines for any pattern.
If Polyline Pattern is set to true, the line type pattern is created over the polyline as a whole (right).
"Polyline Pattern" Property
Re: "Polyline Pattern" Property
I find this example screenshot misleading.
One can hardly see any differece.
Included an other.
Included an other.
- Polyline Pattern 2.png (5.35 KiB) Viewed 20565 times
