pdf. conversion
Posted: Mon Jan 17, 2022 4:12 pm
by Marco Giaccone
Following the User's Guide procedure cannot get .pdf conversion fron this file
The result is a .DWG Drawing that can no longer be opened
Thanks.....
Marco
Re: pdf. conversion
Posted: Mon Jan 17, 2022 4:22 pm
Your problems might stem from the unlucky name of the file:
LABORATORIO CON NEGOZIO.dwg.dxf
The file is a DXF file and should be named:
LABORATORIO CON NEGOZIO.dxf
When exporting to PDF, the export should be named
LABORATORIO CON NEGOZIO.pdf
The file loads and exports to PDF without any issues here.
