hello dears,
I would like to know how to create in a veru easy and fast way the blu lines that are used to make evidence something.
I would like to use something to put in evidenze an area (like the blu lines in the attachment), the idea showded o something similar I like.
thank you for your kind suppurt
BR,.
VS
how underline on QCAD
- perimetro.jpg (53.69 KiB) Viewed 6580 times
Re: how underline on QCAD
Hatch from selection:
https://qcad.org/doc/qcad/3.28.2/refere ... on_en.html
Hatch from segments:
https://www.qcad.org/doc/qcad/latest/re ... ts_en.html
that is called "Hatch". Qcad offers two tools to create a hatch:
It dosent work ... It is a year I am trying
Can you please show me a video on how to do it???
As I said it doens't work, I used closed lines
