Dimension value is overlapped when some files viewed by QCAD
- Registered Member
The problem as the subject, the dimension values is shown right when the file open by other software, please see the attachments.
- 設計圖紙(2).dwg
- (541.53 KiB) Downloaded 487 times
- OpenWithQCAD_2.jpg (1.08 MiB) Viewed 14794 times
- OpenWithQCAD_1.jpg (1.03 MiB) Viewed 14794 times
- OpenWithEdrawings.jpg (679.08 KiB) Viewed 14794 times
Re: Dimension value is overlapped when some files viewed by QCAD
QCAD is a 2D program! Your drawing contains 3D entities what leads understandably to unexpected behavior in QCAD.
If you flatten it to 2D (Menu/Misc/Modify), change the Dim settings from Arrow to Tick, reduce the size of the DIM text from 3 to 2.25, remove the double dimensioning then ..................... it will work just fine in QCAD.
